metric studs
metric studs
Where can a person find good quality & high grade 10.9 ( like a Grade 6- 8 if in USS ) Metric studs & washer nuts in various lengths & sizes??
Grumpy
Grumpy
- I500
- Real Name: Chuck Moser
Re: metric studs
Kenny. If your talking motor studs than I am also looking for some for Dator motors. I was told from Bill Buehn at Anoka that a good source is S&S Fastener in Ham Lake MN. I have not contacted them yet but plan to in the near future
Re: metric studs
Grumpy,
If you need Kawi studs, I have NOS long ones for most of Kawasaki motors Deere used. Sorry, but I don't have any for the CCE/Kioritz motors.
Re: metric studs
I looked around Kansas City today but couldn't find what I needed / wanted, Mac Master Carr also no luck, so I guess I'll be doing some late night Google surcharges.
What i think I need is a automotive double ended style studs M8 X 1.00 X 123.825 mm which seems to be an odd ball length.
Might be able to fudge on the length I need +/- a bit ( I haven't got the case girdle built yet to know for sure on the length I need )
I keep you guy posted if I find a good source for oddball studs like for the Dators & my needs..
Grumpy
Grumpy
Re: metric studs
Grumpy you sure they are 8mm x 1.00mm?
Stardard 8mm size is 1.25 mm.
Re: metric studs
Todd, I have to ck on that but I do know they fit into a 1.00 on my thread chart? I need to get an actual nut that I know is 1.00 or 1.25 in my hands to make positively sure, I've been running into a few thread differences on other metric bolts lately??
Grumpy
Grumpy
Re: metric studs
Todd, you were right they are 1.25 pitch that damn new plastic pitch gauge a guy gave me is molded wrong, guess you can't trust anything you get for nothing anymore ?? good thin I went & checked at Ace Hardware to make sure before I ordered any..
Grumpy
Grumpy
Re: metric studs
So MCM has 140 mm long with 35 mm of thread each end in 8mm x 1.23mm.
$3.40 each.
Just cut off 12 mm on each end and you have what you need.
$3.40 each.
Re: metric studs
I had a Dator stud made from a good bolt , threads were cut on w/ a lathe not a die. , think it will work fine and is good material Wade
- I500
Re: metric studs
Wade , can you whip together about 6 for me in your spare time. Thanks Buddy!
Re: metric studs
sure!! i can have my guy make some i suppose i
- I500
Re: metric studs
I was just messing with Wade but if you really can help me out, that would be fantastic.ic. I actually need about 6 of the larger and 6 of the smaller ones
Re: metric studs
ill see if he is busy , kenny you want some ?? wade
Re: metric studs
Wade, I really need to get my plates back from the race shop, once I get them & drill the holes then I will know for sure on the proper length. I'll ck today to see if the got them cut..
But yes IF you can get them made I'll need some.. Should I get the rod? I think I can order some good cold rolled 4130 or better steel rods I just need to know what type of steel would be equivalent to Grade 6 or 8 studs..
Chuck do you know what Dia mm studs you need?
Grumpy
Grumpy
