Kohler 295 2ax w/ CDI?
Waterboy7
Real Name: Rylie Sobotta
Post by Waterboy7 »
I have a '74 300 that I'm still trying to get going.. I had the cylinders popping off on its own with a mikuni conversion last week, but won't keep going. I've advanced the fly-weight on the flywheel cam when setting the gaps, but still can't get it and it's just becoming a headache now. Was wondering if anyone has ever tried, attempted, successfully put a Kohler 340 2-cylinder CDI system from a spitfire onto a 295 2ax??? That's my next idea for this project.
Let me know!
69camaro
Real Name: Duane Gjerseth
Re: Kohler 295 2ax w/ CDI?
Post by 69camaro »
Rylie, I really hope someone can pipe in on this. I wish I had a answer for you.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
HoosierDeereMan
Real Name: Troy Miley
Post by HoosierDeereMan »
Are you asking if a cdi box will work with a points flywheel?
snopro_deere
Post by snopro_deere »
Im thinking you wanna do a complete conversion correct.. points can be a pain sometimes but you should be able to get it running. just checking its got an inline fuel pump on it right
Fear The Deere
HoosierDeereMan wrote:Are you asking if a cdi box will work with a points flywheel?
He means the whole thing - stator, CDI, coils, but I don't know if they work or not. I believe it's a completely different engine, so I doubt it.
Waterboy7
Post by Waterboy7 »
What I was thinking of doing is take the flywheel, and points & condenser plate off and install a stator, CDI and flywheel from a spitfire Kohler 340. I've never heard of this done so I thought I'd ask.
Thanks guys!
Waterboy7,
I have never tried this, but the crankshaft is the same from the K295-2AX to the Kohler powered Spitfire, so the flywheel should fit. I do not know if the stator will bolt into the cases, but I assume if your were determined enought it could be machined to match the Spitfire cases, if they are different.
Good luck, and please share your results if it works.
Waterboy7
Post by Waterboy7 »
I will keep everyone updated! Thanks for the information guys.
-Rylie
Waterboy7
Post by Waterboy7 »
We'll guys I had a guy, about an hour away from me, replace the condensers and point and then he timed them too... I put a mikuni on it and had it running about two weeks ago! :dance: I still want to try the CDI idea in the future though! Now that I have acquired a couple more Kohler 295 2ax's, and have a better knowledge with the engines since my first project, I'm going to experiment with the CDI idea. So PM me if anybody has an old spitfire (w/ a Kohler 340) laying around :)
Thanks- Rylie
