Whats the innerchange on Liquifire belts?
BombThreat
Post by BombThreat »
I'm ordering some parts for my 80' LF and wondering if a 82' LF drive belt will fit properly? The site doesnt have the 80' listed but does for the 82'.... Also does anyone know if the carb. adaptor froma 78-81 kawi invador will fit the 80' LF? Thanks for the help guys
Mean Green
Post by Mean Green »
Nope, you need the M68715, which was also used on the snowfire and sprintfire sleds. The '82 and up LF's utilized the Deere TR-800 clutch and used a slightly wider M69170 belt. The carb boots will interchange as well as just about everything else from the Invaders to the early LF's. The Invader heads are higher compression, and the carbs although identical, are jetted completely different including the chrome slide valves. Invader carbs are easily identified by having a nipple for a fuel primer between the slide and the carb boot. The Deere carbs have a screw.
Tracy
BombThreat
Ok thanks for the info. I have another question if you guys dont mind... Is 136 and 128psi alright for the cylinders?
