OK here is what I need. The smaller studs are 87 mm total length with 15 mm threads on both ends and diameter is 8 mm. I need 3 of these.
the larger studs wont be as easy, total length is 198 to 200 mm in length with 25 mm thread length on one side and 20 mm on the other side. center of rod diameter is 8mm while the diameter on the threads sides are 10 mm. need 4 of these. Wade, if you think you can help me out, I have some loose studs I can send down your way.
Thanks either way.
metric studs
Re: metric studs
ill pass on the specs , but samples are huge ! wade
sorry guys im not keeping up well with this thread , im pretty busy and havent been on the site much but i can work on this no problem , call me if im not keeping up !! wade
Re: metric studs
Wade my Race Chassis builder says that unless these are heat treated after being made they won't hold up to what I'm using them for, even if there made from the very best material.
Grumpy
Grumpy
