80 LF lost lights and tach last spring
Whiteshell440LC
Post by Whiteshell440LC »
I lost power to my lights and tach, all wires tested good to the plug, am i in for an engine pull?
1980 SF 440
1980 LF 440
1981 TF 440
If the women don't find you handsome, they should at least find you handy.
fastl82vette
Real Name: Greg Cyrocki
Re: 80 LF lost lights and tach last spring
Post by fastl82vette »
Check the prongs in the plug. Sometimes they push in to the plug and you have to pull them back out with needle nose pliers.
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
'88 Yamaha Sno Scoot
'71 Massey Ski Whiz Special
Whiteshell440LC
ill have a look, thanks
1980 SF 440
1980 LF 440
1981 TF 440
Bad voltage regulator could be the cause.
Whiteshell440LC
i swapped out the old voltage reg. right after it happen hoping that was the case(i happened to have a NOS VR hanging around) it didnt help anything
would the coils from a 340 liquid be the same as the 440? just in case i have a bad coil i have a good 340 on the shelf i could steal from
1980 SF 440
1980 LF 440
1981 TF 440
Stators would be the same, yes.
