Heat Deflector WTB
Heat Deflector WTB
Guys
The X8 project is in need of the heat deflector / firewall . Good used is fine as long as it is unmodified, cut, bent, etc. Part numbers : AM53025 and AM53026. Must be off a '73-75 reed inducted sled.
thanks
fastl82vette
Real Name: Greg Cyrocki
Re: Heat Deflector WTB
Post by fastl82vette »
So this one off of a 73 500 wouldn't work??
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
'88 Yamaha Sno Scoot
'71 Massey Ski Whiz Special
No, the piston ported engines have the carb mounted higher, and the opening in the deflector matches that.
There were three slightly different deflectors: one for the Kohler powered sleds, one for the piston ported, and one for the reed inducted Kioritz engines.
fastl82vette
Gotcha!! You learn something new every day.
-Greg
'86 Kitty cat
'77 Cyclone SOLD
'84 Snowfire
VintageCatMan
Real Name: Nick Freatman
Post by VintageCatMan »
Rainville use to have some of those i believe
Nick Freatman
smitfire
Real Name: Dustin Smit
Post by smitfire »
I have a 74 jdx8 parts sled and a 75 jd 800 parts sled out here.
DLDeere
Real Name: Howard Olson
Post by DLDeere »
How about this one? This is from a 74 or 75 JDX. It has a place for the coils and CDI.
DL Deere
Detroit Lakes, MN
73 JD 400, 500, JDX4, JDX8
74 JDX4 Special, JDX8
74 JD 295/S
75 800
76 Liquidator
77 Liquifire
78 Liquifire
80 Liquifire
80 Spitfire
83 Snowfire
A quick look on JDParts.com indicates there were a couple more versions than I thought.
295/S and the one pictured above, which appears to be for a late 400 ( with CDI obviously ).
400brian wrote:A quick look on JDParts.com indicates there were a couple more versions than I thought.
As well as '75 JDX8/800.
