Need a few parts for 83 Sportfire
silverbullet
Real Name: Jamie Scott
Post by silverbullet »
Looking for a couple parts to get 83 sportfire finished up.
Need Rubber Boot between the Carb and Airbox
F2762R Spring for oil tank
AM52305 Taillight
Jamie
1-1972 500
1-1974 JDX8
2-1975 600
3-1980 440 Trailfires
2-1980 Liquifires
1-1981 Liquifire
1-1982 340 Trailfire Special
1-1982 440 Trailfire LX
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-1982 Yamaha excel III
1-2000 Yamaha SX500R
1-2016 ZR 9000 RR
ihengineer76
Real Name: Tom Rehberg
Re: Need a few parts for 83 Sportfire
Post by ihengineer76 »
The carb boot is available through Matt on Newbreed, and the taillight is still available through Deere.
1975 340/S - I-500 raced sled
Hi guys,
Unfortunately for us Deere discontinued the taillight earlier this year after nearly 42 years in production.
silverbullet
Couldn't find the boot on newbreed website. I need the one between airbox and carb. Maybe I just missed it. Couldn't find a part number in Sportfire parts book either. The one I took off is part number M67939, same as Trailfire. Is that the right one or is there different one for Sportfire?
Also I did check with deere on taillight but as Joe said they have discontinued them and only dealers that showed them in inventory didn't have them left when I called.
Jamie
1-1972 500
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
Several other brands used this same tailight/lens combo like Rupp, Scorpion and others.
There is no boot between the carb and air box, the box clamps right on the carb.
I don't have the intake to carb boot right now, not available.
silverbullet
That would be why parts book doesn't show one. Thanks Matt, I will try it that way.
Still looking for oil tank spring.
Jamie
1-1972 500
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
I'm sure we have one around here Jamie. I'll look.
largecar04
Real Name: scott ohm
Post by largecar04 »
I've seen a few people looking for the oil tank springs. I just bought one from deere last fall so they should still be available new
02 arctic cat zr 800 efi
02 arctic cat zr 800 cross country efi
silverbullet
It does look like Deere still can get the oil tank spring. They are also used on 4020 tractor so thanks for the help.
The air box I have on this Sportfire has a notch that doesn't line up with carb. I found a parts book that lists an adaptor M68655.
Jamie
1-1972 500
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
