78 Cyclone
78 Cyclone
Ok guys need some help with my 78 cyclone. It idles fine but I cant get it to clean out and it loads up the lower end. Its like its running real rich. I am going to change the crankcase seal behind the clutch to rule that out, but any other ideas? You think its the needle and seat?
- Real Name: Keith Bylin
Re: 78 Cyclone
hello kuku,
A friend of mine has the exact sled (440)with the same issue. New crankcase seals and all! So I will be watching the replies. He did replace the needle and seat but I am not sure he got the correct one from the local AC dealer. They are sized and made of different materials. Thing is a pig on fuel too. Maybe 45 miles to a tankful. Quick and dirty way to test the PTO seal is to spray starting fluid at the seal and listen if the engine changes RPM. Please be careful spraying starting fluid around a running motor!! Many parts are rotating and some are hot!!! Have you checked the timing?? Don't think my friend has his Cyclone.
keith
keith
Re: 78 Cyclone
Ok,
I will start with the seals, and I did check the timing and it is right on.
I am also wondering what symptoms a CDI box going bad does?
- HoosierDeereMan
- Real Name: Troy Miley
Re: 78 Cyclone
What is your idle RPM? Most guys will set the idle 150 to 200 RPM under clutch engagement. If the idle RPM is too low and you blip the throttle the sled will stumble all over itself and bog down.
Troy
Troy
Re: 78 Cyclone
If you do not know the history of the the engine, I would replace the crank seals first thing. Also, I would check the cdi system, it sounds like either a weak spark or loss of one cylinder.kuku wrote:Ok,
See the topic in the FAQ section.
http://www.jdsleds.com/community/viewto ... f=5&t=2473
- Real Name: Les
Re: 78 Cyclone
Having the same issue with my 78 Liquifire. Mostly the MAG side cylinder,rebuilt her last year. Fuel pump pulse line is on the PTO side so I have semi ruled that out. Have had carbs apart,new needle valves and seats,adjusted the needle on the slides,got her running better but not right yet. My next thing is the inrichment valve,got a new one only $5,thinking the old one may not be sealing completely. Having a simler issue with my 79 El Tigre,got to love 30 plus year old carbs.
