Barn find
Re: Barn find
I've got OEM style Juice brake line someplace, I just have to look for it. It might be Up north??
Have you driven a sled with a twist grip? IF not you might want to consider a regular thumb type throttle.....
Just my $.0685 worth
Grumpy
Grumpy
Re: Barn find
The cable is 38" long, the housing is 35" long.
There are custom cable suppliers out there I believe.
Here's a couple of shots:
Re: Barn find
While the plastic brake line is available, I recommend the Stainless braided model usually for sale on Ebay for about $40.00. I have stainless on both of my hydraulic brake sleds.
- I500
- Real Name: Chuck Moser
Re: Barn find
Tension screw on the underside of the twist grip, I would recommend removal and throw it as far as you can. It's an accident waiting to happen.
- 340sracer
- Real Name: glen wasmuth
Re: Barn find
Thanks for the info. Yes I have used a twist grip having completed I-500 and I-250 with 340s and if I remember right the other cross country sleds that I had and liked it for cross country but not good for oval. If possible I would like to restore the 340s to the way I raced it.
I got pretty excited when I saw the pictures of the twist grip & cables as I thought at first they were for sale !!
- 340sracer
Re: Barn find
Found my yellow helmet yesterday, that I used in the I-500 and I-250 in 1975 .Any ideas where I can get it refurbished ?
- 340sracer
Re: Barn find
Need tie rods and ball joints for 340s, any ideas where I can get them from?
thanks Glen
thanks Glen
- HoosierDeereMan
- Real Name: Troy Miley
Re: Barn find
Glen,
The ball joints are called Heim Joints. I think I bought mine through McMaster-Carr. If you have a local bearing supply house near by they would probably carry them or could get them for you.
Troy
Troy
Re: Barn find
Glen; its easy, you just make up a new set!
Go here: http://www.jdsleds.com/community/viewto ... ods#p44831
Troy and I re-built a pair of 340/S' a few years back, and we documented most all of it here on the list, you just have to find it.
The problem in making them was that we didn't have the ability to cut left hand threads. So, we tapped the aluminum rod right hand on both ends, put a male rod end on the steering shaft end, screwed the adjuster into the outer end, and put a left hand thread female rod end on the end of that.
Then after all that, we looked at the 340/S that Ed Kruel had at the time ( which was a JD team practice sled ) and saw that they had made them up out of steel tube.
- 340sracer
Re: Barn find
What SP should I Be running in 340/S? The book says champion N-19v
Thanks Glen
Thank you for the Info on the tie rods
Thanks Glen
- HoosierDeereMan
Re: Barn find
Glen,
The N-19v is a surface gap plug. The NGK equivelent is a BUE plug. The problem is the older Prestolite CDI boxes like the one used on the 340/S may not be able to fire the surface gap plugs. I have a Hewtech fireplug CDI ignition on my 340/S and I run NGK BR9ES plugs. The BR9ES has the traditional electrode and makes it much easier to read the electrode when you are trying to dial in carburetor jetting.
Troy
Troy
- HoosierDeereMan
Re: Barn find
Here is a picture I have of Ed Kruels' 340/S ETD practice sled tie rods. They replaced the smaller tie rods with heavier steel tube.
Re: Barn find
I run the AC SV4XL plugs in my 340S. JD P/N 53223
Re: Barn find
If the surface gaps were the hot setup, we'd all be running them...and we are not.
NGK BR9 or 10. 10 is the coldest.
I remember Grumpy telling us that only the hottest of Prestolite ignitions would consistently fire the surface gaps.
- 340sracer
Re: Barn find
Here is an update on the restoration.
I want to thank Ryan Baird from Ontario for sending me a twist-grip kit so I can get the throttle cables copied.
If that doesn't work, he said I could use them for the time being.
Attaching a couple pictures. The motor is ready to drop in & the running gear is now installed.
![Clap :clap:](./images/smilies/eusa_clap.gif)
