this motor has 100 psi and 105 psi
timing has been set with a dial indicator.
points are old but cleaned and set with feeler gauge as per service manual
plugs gap set as per service manual and when running plug look nice and tan, plug are new about 5hrs
new carb gasket kit
metering arm set as per manual with a new rubber tip needle thinge.
new fuel lines and pick up in tank 40:1 mixed fuel
all the lights work but the speedo does not
tach works
low idle 1 turn out
high speed about 1 turn out
new engine seal mag and pto
ok so after all that I got it running it will hold a good idle about 2400 rpm via the tach, when you hit the throttle to WOT it has a slight bogg but I believe it just a poor clutch worn and old, but has been cleaned. so it will run right up and sound good and even. I tuned it while under load and comparing it to the other sled with same motor I am happy. Pulls good and responds as expected.
I shut it down by letting it idle down and run for a true min. then turn it off, If i go to try to restart within the first 5 min it will start up and be just fine. where the problem is after about 10 plus it is very hard to get started. like its flooded. still have spark. I will always end up having to pull the crank bolts near the bottom and pull it over a few times then it will pop and I repeat until it almost wants to run. reinstall bolts and start. it will take a few to get started. Also after sitting for night if I just pull to start it needs a prime but I have to be careful or it will flood. If I just try and pull it with no prime, it will flood. with ether choke on or not. If I disconnect the fuel line and let it run until its out of fuel, then wait 15 min reinstall fuel line it will need a prime to start but will run fine after all that crap.
What do I check next.
If I change the setting on the metering arm it will flood and die, any less it won't pump from the tank. by looking at the vapour return line and comparing it to other I have I would think I have it set right.
GRRRRRRRRRR.
![Evil or Very Mad :evil:](./images/smilies/icon_evil.gif)
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
