Needed: Sportfire jackshaft
I am in need of a good Sportfire/Trailfire jackshaft. Don't ask me how but mine is bent. Guess I beat on it a little hard.
Re: Needed: Sportfire jackshaft
I probaby have a good one. Are they same across the board for Trailfires, Liquifires, Sportfires?
I know I just had two welded up due to being worn. PM me if interested.
427cobra wrote:I probaby have a good one. Are they same across the board for Trailfires, Liquifires, Sportfires?
It sounds like JDRob has me hooked up with one, but FYI Liquifires are longer then the Trail/Sport version.
Sounds good. Thanks!
I might be wrong, but I thought the 80-81 Liquifire shafts were the same as the trail / sport shaft. 82-84 had a longer shaft to eliminate all the shims behind the secondary.
That may be true, I just know I had purchased a Liquifire shaft in the past that didn't work.
- jdrob
- Real Name: Rob
Jackshaft is on its way.
Jdrob
- Real Name: Bob Amber
I'm pretty sure that the Liquifire (riders) have longer shafts than the trailfire/sportfire riders.
Signed,
Liquifire Bob
ps- you may delete this, I'm done humoring myself.
Signed,
Liquifire Bob
Bob you opened a can of worms now lol....But I think most of us own both so......
Ugh....guess that means the direct drive sleds have no shaft.:o
Boys!! Don't make me stop this car!!
Just because you have a longer shaft (on a Liquifire) does not mean you know you to use it.DeereKid9 wrote:I'm pretty sure that the Liquifire (riders) have longer shafts than the trailfire/sportfire riders.
Signed,
Liquifire Bob
