Hello,
I'm looking for a great condition track (116"x15"x2.0" pitch) for my '78 Spitfire.
I believe this is the same track for the Snowfire, Sprintfire, 79-80 Trailfire and 80 Sportfire.
I would also be interested in a used Kimpex track of these specs, I believe they used to make them.
Ty
620.384.6085
Looking for a Spitfire track
Re: Looking for a Spitfire track
Or any ideas about a possible track upgrade? I know the 2.00" pitch is a problem to find. Could I modify this sled and make a 2.52" pitch gear work, it seems more possibilities for a track open up. I am good with metal and know a good machinist...... Just brainstorming at work, haven't had much time at home to dive into the project yet! Thanks.
the small front drive sprockets on the Spitfires, Snowfires, and Sprintfires, need a thin in thickness track to get around them successfully in sub zero temperatures to drive the track on the direct drive sleds. You can change the sled over to another style track and drivers, but you would need to convert the sled over to a chaincase, as just larger drive cogs being added will take the gear ratio (if you will) and throw it out the window. It will cause the sled to be boggy and such when trying to get it moving. It can be done, but will take some creative carpentry. That is why John Deere used such a thin track on these little sleds. Hope this helps explain...Rob.
Ty,
Let me do some digging in the parts stash, I think I have an early Trailfire/Sportfire track in good shape.
1980 Liquifire
1983 Trailfire LX
Others
67 Olympique
72 Elan single
72 Elan 340 TNT Swap
74 Elan Twin
78 Elan Deluxe
87 Phazer Deluxe
89 Formula MXLT
1983 Trailfire LX
Others
67 Olympique
72 Elan single
74 Elan Twin
78 Elan Deluxe
87 Phazer Deluxe
89 Formula MXLT
Make sure to measure the width. I seem to remember the Trialfire/Sportfire cleated track being wider. Spitfire track will fit the Trailfire/Sportfire. One fits one but not the other. Best to check.
Yeah from what I have read the earlier Trailfire/Sportfire,.... the years I mentioned above should be the same track width as the Spitfire.
Thanks for all the info and digging for parts! I sure appreciate it and will verify the correct width before we move forward.
- 69camaro
- Real Name: Duane Gjerseth
I think only the 79 Trailfire track will work on a Spitfire. 80 up are too wide I believe. I have a couple used 79 Trailfire tracks. I'd part with one but I need to keep one for a spare for my Sprintfire and Snowfire.
75-340/s
76-340 Liquifire
77-440 Liquifire Custom
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
81-Kawasaki 440 Invader
76-340 Liquifire
78-440 Liquifire
84-Liquifire
84-Sportfire
84-Sprintfire
84-Snowfire
78-Polaris TXL
82-Indy 500
91-XC 400
91-Indy 500 Special
94-Indy 440 Special
95-XCR 440 Special
96-XCR 440 Special
99-XC 600
04-XC 700
- jdrob
- Real Name: Rob
The trailfire/sportfire tracks up to 1980 will fit. Same width. 81- up are the wider ones.
Jdrob
Ok, Duane and Stephen, could you guys send me some pics of the track you have and check that they are 15" wide..... and how much you would want for them?
Thanks for all the info and help guys, this site is really sweet. I love reading all the info and the stories from back in the day!
The original post and Rob are correct, the Trailfire/Sportfire tracks up to 1980 fit the DD sleds. The wider 81-84 cleated track rubs the tunnel.
