80 liquifire won't go
Hey everyone l, im lookin for some thoughts. I just resealed the motor in my liquifire. Got it back together and running. Fires up no problem. With the track in the air it takes off all the clutching seems to wrk fine. Once on the ground however it won't go fwd. Thanks ahead of time for any help.
75 jd 800 - original
80 jd trailfire 440
2-79 jd trailfire 340
71 ski-doo nordic 399e
80 jd liquifire 440
80 jd trailfire 440
80 jd liquifire 440
Re: 80 liquifire won't go
What's it do when on the ground? Bog or flood out, wont rev up? Are the clutches rebuilt with correct springs, weights, etc..?
Check the belt deflection. Maybe you're getting too much belt slippage...??
The belt it slipping on the primary is wat I've been able to see. Ordered new belt should be here Thursday
80 jd trailfire 440
80 jd liquifire 440
80 jd trailfire 440
80 jd liquifire 440
