1980 Liquifire Project
Packers29
Real Name: Andrew Engels
Post by Packers29 »
Got the parts I need thanks Sledder670 for the vent!
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Packers29
Re: 1980 Liquifire Project
Post by Packers29 »
Well doing work tonight figured out the bearing on the jackshaft on the clutch side is bad so time to tear it down again.....
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
There's a good chance the shaft is worn also. They can be built back up by welding and turned down. Of my 3 Liquifires all have had cracked inner bearing races on the secondary side of the Jack shaft.
Packers29
Post by Packers29 »
I have an extra jack shaft :) so im somewhat prepared! anyone tell if this bearing is correct? http://www.napaonline.com/Catalog/Catal ... 0338932779
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Yep...SKF in a NAPA box.
The chain case side is 7/8" ID
http://www.napaonline.com/Catalog/Catal ... 0338931083
So if replacing both Jack shaft bearings you will need one of each.
Packers29
Post by Packers29 »
Definitely will replace both thanks!
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Might also want to take a look at the track driver bearings. The bearing on the spedo drive side tends to take a beating (because of water).
That takes 2 of the 1" ID bearings
Packers29
Post by Packers29 »
Alright ill take a look tomorrow. :beers;
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Packers29
Post by Packers29 »
Found the cause
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Packers29
Post by Packers29 »
So today went to a smowmobile show today notice what I ran into. A 83 and a 80 with a 84 hood. Then when I got back worked on replacing the collar for the bearing then went on a gunk cleaning spree and then took the skid out and found a few problems...
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Those other liquifires need a warshing!
Packers29
Post by Packers29 »
Did some suspension work today, I would say the rear shock is no good haha
https://vimeo.com/117118281
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Packers29
Post by Packers29 »
Did some rear skid work put some nice slides on just waiting for a rear shock.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Packers29
Post by Packers29 »
Got the shock today!!!
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
