Need Help With Ski's
- Real Name: Jamie Scott
I have 3 different NOS ski's. I need help with figuring out what part number they are. First one in picture is AM54678, last one is AM52884. What is middle ski look like? Box says they are AM52884 but don't look same as bottom ski. Any idea what this ski fits???
1-1972 500
1-1974 JDX8
2-1975 600
3-1980 440 Trailfires
2-1980 Liquifires
1-1981 Liquifire
1-1982 340 Trailfire Special
1-1982 440 Trailfire LX
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-1982 Yamaha excel III
1-2000 Yamaha SX500R
1-2016 ZR 9000 RR
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
Re: Need Help With Ski's
Can you get a better picture showing the slot in the rear mount area for the wear rod placement. Fire Series skis had a dog-leg like bend at the rear of the wear rod.
Here is more pics of ski in question. It is a Deere ski but not sure what part number.
1-1972 500
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
The ski is pre-1978. I am thinking 77 Cyclone/liquifire.
What's the difference between AM53318 and AM53578 ski ? I have four of these that I thought were AM52884 ski's. At least that is what label on unopened boxes said.
1-1972 500
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
- I500
- Real Name: Chuck Moser
Little hard to tell by the pic but looks like early Liquifire.
Bottom picture..AM52884. JDX4, JDX6, JDX8, 300 and 400 Snowmobiles (s.n. -30,000) - 13Oct03
The bottom ski with the flat top loop is definately a '74 100/JDX ski. But not original to a '72 or '73, though it may have been listed in parts as the replacment.
After that the book gets confusing. It looks like AM53318 is for a two bolt wear bar, and AM53578 is for a three.
However, AM53578 is listed as the ski for the 340/S, but they show it as a 2 hole bar. THe 340/S ski also did not have the pad welded across the ski for the rubber bumper to bottom out on.
What would the front shock mount look like on the AM53318 or AM53578? The top Liquifire ski has taller mount and the bottom JDX ski has shorter mount. The ski in question also has shorter mount. The boxes for middle ski did have a M63739 part number on them as well but can't find what that number is for.
1-1972 500
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
1-1974 JDX8
2-1975 600
2-1980 Liquifires
1-1981 Liquifire
1-1982 Sprintfire
1-1983 Trailfire LX
1-1983 Sportfire
1-1983 Liquifire
1-2016 ZR 9000 RR
That's what's so confusing. The ski has the shock mount from a '74, so side-mounted shocks as opposed to above the spring like everything after that year. But it has a round loop, those should be flat.silverbullet wrote:What would the front shock mount look like on the AM53318 or AM53578? The top Liquifire ski has taller mount and the bottom JDX ski has shorter mount. The ski in question also has shorter mount. The boxes for middle ski did have a M63739 part number on them as well but can't find what that number is for.
Could it be a 295/S replacement ski? It's not aluminum is it? Maybe a steel replacement for the aluminum ones?
Maybe not, every photo of a 295/s I can find has the tall shock mount.
