Help with 340s
MWB
Help with 340s
Post by MWB »
I'm putting my 340s back together and things aren't matching up quite right. The bearings on the jack shaft and drive shaft, which way is the collar on the bearing supposed to be facing? I have them facing the right side but when I tighten the secondary clutch on it binds up. ( with cup washer facing in) If I turn them the other way it looks like the top gear would hit the bearing or gear case. And then my next though is the cup washer on the secondary side does that face in or out? I have the parts catalog but the diagrams aren't the best. Any help would be appreciated!
75 340s
73 JDX8
62 Polaris Snotraveler
69 Arctic Cat Panther
69 Johnson Skee hourse
70 Shi Doo TNT
80 Yamaha Enticer
Re: Help with 340s
Think of it this way, the collar faces the splines. It's been a looonnnggg time since I did a 340/s but I'm certain it's the same way.
MWB
Re: Help with 340s
Post by MWB »
Ok, so collars facing toward gear box?? (no splines on the clutch side) Which is the way I have them. Then cup facing out? Or I'm missing something else. I don't know... This is what happens when you tear something apart too many years ago and then try and remember how it goes back together. :wall:
75 340s
73 JDX8
70 Shi Doo TNT
80 Yamaha Enticer
jdjock
Real Name: Tom Schuster
Re: Help with 340s
Post by jdjock »
Pm me with your name and address and I will send you a copy of the page from the service manual. Shows all parts well. Tom
