Looking for a Ski Shock - AM55279
- Real Name: James
I am looking for a ski shock for a 1983 JD Sportfire. New or used will work, so long as it is not leaking oil. Thank you.
Re: Looking for a Ski Shock - AM55279
- Real Name: James
I did look at the newbreeds website but was not sure if one of their shocks would match up. thanks.
About all you can do is get close to the "open-closed" dimension and the end bushings. Might want to consider replacing both sides.
I don't have the ski shocks available at the moment. It's actually a Polaris suspension shock for a spring-over but it's the right dimensions for the skis. If you google part number 04-237 you can find it elsewhere.
http://www.newbreedparts.com/newbreed/i ... uct_id=338
- Real Name: James
Thank you very much guys. I will look up and buy the Polaris shock.
Matt, is 04-237 a Polaris number?
