Liquifire Secondary Clutch
Quick question, will an 82 trailfire secondary work in place of a 82 liquifire secondary? My secondary is caput have the spare, can not see any difference at all unless it is the sping. That can be easily replaced. Not able to find a model number on either so hoping someone would know Once thats answered on to finding a new drive belt
1980 Trailfire 440 (parts sled), 1980 Trailfire 440, 1982 Trailfire 440 1976 Liquifire 440 (Project), 1976 Liquifire 340 1982 Liquifire, 1982 Liquifire (Project), 1983 Snowfire, 1983 Sportfire
Re: Liquifire Secondary Clutch
Nathan,
The original 82 Liquifire driven has taller towers for the 1 3/8" belt over the 80-81 Liquifire and 79-84 Trail and 80-84 Sport driven set up for the 1 1/4" belt. It also has a 44 deg helix, but I think the spring is the same.
I hope this helps,
I hope this helps,
Are you gonna run a tr800 primary or a comet 102c?
Using a rebuilt TR-800. So for Joe's response, i can take the top portion from the LF secondary and move over? Issue i have is the shieves are done for and can not heat/pull bully them into coming apart. Super excited will be the first snow this has seen in over 15 years. Engine runs strong cant wait to go play on it.
