1980 Liquifire Project
Re: 1980 Liquifire Project
The best way to know for sure is a coolant pressure tester. Most auto parts stores will have them as a loaner tool.
- Packers29
- Real Name: Andrew Engels
I think that is what it is doing nick I noticed coolant around the studs. The PTO side seems to be the one leaking the Mag side i see no coolant leaking. The head must be warped and not sealing correctly. Ill have to take a closer look to make sure its flat along with the jug.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Andrew check the stud length to be sure they are all the same and one or two have not worked loose.
Also be sure all the head bolt washers are the same thickness.
A thinner washer allows the acorn nut to bottom out internally before the head is at the correct torque.
- Packers29
Will do thanks JDT.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
Open end nuts like the ones one my rebuilt motors won't bottom out like the acorn nuts could.
- Packers29
But then you don't have the awesome chrome acorn nuts!
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
I have seen examples where the head nuts were over torqued and this caused the studs to stretch.
Then the acorns bottom out and you can't get the gasket tight.
Quick fix is to used thicker washers.
- Packers29
Thats the plan add some more washers.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
- Packers29
It's apart again.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
If your already aware of this I apologize.
As odd as this may sound, the manual for the Kawasaki Invaders tell you to apply Kawaibond (basically yamabond or threebond case sealer) to the head gasket.
The OEM Deere gaskets had a sealant preapplied.
Scraping the old material off the NOS and using new sealant is the way to go
- Packers29
I did not know that. Rob suggested using copper gasket material on the weisco gaskets I ordered. Essentially that does the same thing right?
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
- Real Name: Lincoln Huffman
Was the sea lent dry or hard on the nos gaskets? I have used several sets just the way they are and had no problems. How do you scrape it off without hurting it, and what do you use in place of? Thanks lincoln
Scrape it with any tool gentle enough to get the old residue off then any bond like the yamabond or threebond. The copper sealant is a great idea too
- Packers29
JDRob is helping me finish the project A new head and redone recoil. Thanks Rob.
1978 Liquifire 440
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
1980 340 Trailfire
1981 Sportfire
1984 Liquifire
1984 Sprintfire
1984 Snowfire
