dual carb swap cyclone
looking to do a dual carb swap on a 1976 440 cyclone serial number -70000. i have a parts sled that is a 1976 340 liquifire serial is 70000- Can i use the ones off the 340 liquifire? i know they arent the same and id have to do some jetting. i know the stock 440 cyclone carb is a vm34... what are the 340 liquifire carbs? any help would be great
Rebuilding aluminum idler wheels for you! new bearings, solid rivets, and polishing. PM for details
Seeking 76 Cyclone 440 parts
Low black windshield
Complete seat or just the cover
Re: dual carb swap cyclone
Cyclone/Liquifire all use a VM34 carb. You'd probably have to do some jetting.
Check this link, service manual for Cyclone/Liquifire.
http://www.vintagesnow.com/John_Deere_f ... one_SM.pdf
The Liquifire swap is common. The 340 carbs use the same carb body. Jet the carbs using the 76 liquifire carb specs as a starting point.
Sent from my XT1080 using Tapatalk
[quote="harleysportster"]The Liquifire swap is common. The 340 carbs use the same carb body. Jet the carbs using the 76 liquifire carb specs as a starting point.
should i use the 340 or 440 liquifire specs?
You should start with the 440 jetting.
can anyone give me jets sizes for the 440? or a place where i can find that info?
I posted a link to the service manual, its in there.heiner921 wrote:can anyone give me jets sizes for the 440? or a place where i can find that info?
thank you
How are you mounting coils and cdi box? They are mount on a plat that bolts to the single carb intake. Obviously won't work with the dual carb setup. And on the l/c motor they are mounted right to the case
Here is a picture of one of the members here of his conversion. He modified the bottom of the coil mounting plate.
However you chose to mount the ignition system make sure it is bonded (grounded) to the engine case.
This can be done with direct mounting metal to metal or by use of a grounding strap if you chose to remote mount it from the engine.
harleysportster wrote:Here is a picture of one of the members here of his conversion. He modified the bottom of the coil mounting plate.
do you know the member who did this? i have a few more questions for him...
His name is Eric Anderson aka... 427cobra. I believe he has since sold the Cyclone. He does pop in and out occasionally.
