78 spitfire won't rev up, bogs down
bunk79
Real Name: Brandon
Post by bunk79 »
The engine runs great for awhile.. Then it just idles and won't rev up.. This seems to be a common problem with Deere sleds.. has anyone solved this issue? I'm going to try a fuel pump to see if that changes anything.
I replaced the crank seals, cleaned carb and replaced spark plugs.
Thanks for any help you can offer.
bunk79
Real Name: Brandon
Re: 78 spit fire dies after warming up
Post by bunk79 »
Adding to the above post.
Jd sled rider
Real Name: Lincoln Huffman
Re: 78 spitfire won't rev up, bogs down
Post by Jd sled rider »
I had the same problem with y 83 liquid I just finished, tinkered with it for hours, then I called a friend and he said to remove the exhaust pipe! It ran like a dream. The problem was a mouse nest in the pipe. Problem solved. Later lincoln
Always a good idea to clean out the acorns, dog food, seat foam and twine from the exhaust.
Your revving problem could be a faulty CDI. Try swapping out a know good unit.
