1984 John Deere Sprintfire For Sale $850 o/bo
I bought it not to long ago from the original owner in central MN. I have gone through it to an extent but not 100 % I've only put a few miles on it as I'm too hefty for the Lil things. Pretty new Full rubber track converted, and it still has the nubs on it! Which is impossible to find. Here's the good and bad list:
Good:
Good compression
All lights work
Original seat, one small crack on back corner
Pretty straight tunnel, small crease on both sides by rear.
Throttle and brake blocks aren't cracked
Oil tank full with Amsoil
Fuel tank full with stabilized 92oct
New fuel line in tank and new grommet
New NOS belt
Clutches cleaned and aligned and in good shape
New spring in primary clutch
Hood hinge is good
Hood has a crack in front corner and both sides in back by common fail spots amature repair by original owner
Skis in decent shape with new wear rods
Exhaust painted
All new oil lines and filter and bled
New fuel line and filter
Carb cleaned
Coolant flushed and filled
New plugs
Track aligned and tensioned
Bad:
Needs new gas cap
Disabled the Rev limiter
Have not done crank seals
Takes 15-20 pulls to start when cold, but idles good and did 50mph with me on it!
Re: 1984 John Deere Sprintfire For Sale $850 o/bo
More pics
More pics
More pics
More pics
Sled is sold and went to new home!
