for !984, 440 Liquifire found on Ebay
eBay item number:
121801222938
Now this is a must if you own a 84,440 Liquifire
Grumpy
Re: for !984, 440 Liquifire found on Ebay
That is pretty much standard fare when you do a search for JD Liquifire on ebay these days. Still haven't figured out where it mounts. Can you put an accessory drive apparatus in place of the oil pump and just run mixed fuel?
70WT1
Post by 70WT1 »
I have looked and looked for one of those :bonk: :bonk:
1980 Liquifire
1984 Trailfire LX
1982 Liquifire
1983 Liquifire
Possible third cooling option on warmer days with thin snow conditions....like most of this winter season.
Matt, if this catches on, you might have to start selling drive belts at New Breed.
Bought all eight so that I can start putting them on every restoration. :angel:
Work quickly so you can submit patent rights on the mounting hardware.
