Help with cylinder id
78LF
Real Name: Shaun
Post by 78LF »
I have some cylinders that have no casting numbers on them.
They came in open boxes that have a label on them.
How can I be sure they are as labelled on the box?
Re: Help with cylinder id
If they are original boxes, the cylinders are for 340S.
Sent from my XT1080 using Tapatalk
By this picture they look like 340S.
TASKY
Post by TASKY »
They must be sitting on a glass shelf or something, display cabinet? Cross Country hand book in the lower right amongst other treasures lost to time. Sweeeeet!!!
78LF
Real Name: Shaun
Post by 78LF »
They look like 340/s and are in 340/s labelled boxes, but how do I confirm they actually are 340/s? Shouldn't there be some casting numbers or some kind of marks on them? I also have another set of cylinders that look similar, but with a bigger bore.
This set has casting numbers, does anyone know what they are for?
78LF
Real Name: Shaun
Post by 78LF »
Cabindweller
Real Name: Jerry Zebro
Post by Cabindweller »
The bigger bore cylinders are for a 440/5 motor would be my guess. The motor was used in the 74 500 and 600. I am interested in those if you are selling them.
TASKY
Post by TASKY »
I dont know if this helps or confuses the issue but the 340/s cylinders I just looked at had no casting numbers in that area. They had a small 3 digit stamp on the bottom of the bottom cooling fin under the right beneath the exhaust stud. I will have to dig up others to confirm a pattern.
78LF
Real Name: Shaun
Post by 78LF »
With the second set of cylinders, I was wondering if they were for the 440/5 motor, but I don't have anything to compare casting numbers. I do have a 340/5, these cylinders look like them externally, but I hate to disassemble this motor to find the casting numbers. Does any one have a record of casting numbers? Cabin dweller, I'll keep you in mind if I decide to sell the second set of cylinders.
Jd sled rider
Real Name: Lincoln Huffman
Post by Jd sled rider »
I would also be interested if you decide to sell them. But I also hope you find a use for them like on your own sled. Thanks for sharing your find and I hope you find what you need. Later Lincoln
Cabindweller
I am certain the casting numbers on the big bores are for the 440/5. I have a 340/5 motor tore down but it is stashed away at the moment. I know there is a casting number on those jugs similar to the number that is on the 440/5 jugs you have. Might be something like 5050000, just guessing.
jdrob
Real Name: Rob
Post by jdrob »
I agree with Tasky. The 340/s and 295/s cylinders had no casting numbers in them. I had a set of 295/s cylinders from my sled and the previous owner traded them out for 340/s cylinders. So he could cheat and run in the 300 cc class. Brock Weber and I looked over the 295/s cylinders very well. Only way to tell is to measure the bore. Hope this helps. Jdrob.
Jdrob
TASKY
Post by TASKY »
The no casting numbered cylinders have a 2.365 marked on them I believe that is the bore of the cylinders in inches. Converted to millimeters it equals 60 mm The bore size of a 340/s 2.365inches = 60.01 mm.
The bigger cylinders are marked with what I believe to be 2.675. I looked up the bore on the 440/5 motor and came up with 68 millimeters. I converted 68 millimeters to inches and came up with 2.677 inches.
I don't know what casting numbers or absence of them the 340 piston port motor cylinders have on the JD 400 but given that they came out of a 340rs/2 box and the bore matches I want to believe they are for the 340/s. I know the 440/5 motor had casting numbers just like in your picture I dont remember what the sequence is.
I would speculate that you have 340/s cylinders and 440/5 cylinders.
78LF
Real Name: Shaun
Post by 78LF »
Thanks guys, I suspected that they were 340/s and 440/5 cylinders, but I wanted to be sure. If the 295/s and 340/s cylinders do not have casting numbers, what about the heads?
78LF
Real Name: Shaun
Post by 78LF »
I have a set of heads without casting numbers.
