John Deere Sprintfire 1983. Long time project....
acesillini06
Real Name: Matt Cappel
Re: John Deere Sprintfire 1983. Long time project....
Post by acesillini06 »
I would call cometic to order the correct ones. C1020S
SS440-80
Real Name: Robert
Post by SS440-80 »
acesillini06 wrote:I would call cometic to order the correct ones. C1020S
I will do that :)
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
SS440-80
Real Name: Robert
Post by SS440-80 »
So now the project continue :shock:
The sled is in a garage at my work and lifted up on sled lift.
The Fuji/Polaris 440 has to come out :bonk:
And out it is :)
With oil tank and gas tank out, it's time for some cleaning.
BEFORE
AFTER
And the decals removed. I don't know if I'm gonna get new ones or go for high polish :think:
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
When having parts loose, got to clean them... :D
Oil tank cleaning outside and inside
It was not very dirty, but it made some difference
I really wonder how drunk the previous owner was when he cut the wires so short? :evil:
(sorry about the bad photo)
But nothing is impossible.
And the oil level sensor is like new again, working perfect. :dance:
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Nice repair job Robert.
SS440-80
Real Name: Robert
Post by SS440-80 »
Thanks JDT!
Now when I have almost all parts and finally finished other projects and taking the time for the Sprintfire, I'm really all in to get it back on snow again :D
Yesterday I started with the motor.
Oily on the outside :shifty:
Brake clean and cloth works fine
Not completely clean inside, but that's my own doing. I sprayed the crank and cylinder barrels with MoS2 oil when I got the parts home.
Clean
Last winter when I ordered some sled parts, I bought a oil seal to test if it would fit... and it fits perfect :dance: But I will have to get one more before I can put the motor back together. And the crank has to get new bearings too. SKF of course :mrgreen:
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Yup your deep into it now!
SS440-80
Real Name: Robert
Post by SS440-80 »
Was not too hard to change bearings on the crank.
Bearings off on both sides
Warming the new bearing a bit before pressing it on to the crank
A hydraulic press is just a big MUST :beers;
But always remember to fill the crank center before pressing, it's so easy the bend the crank otherwise
New SKF 6206 C3 mounted on the crank :dance:
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Looks good but I have to ask. I noticed the bearing number on the box was 6202-2RS1. That part number looks to me to be a sealed bearing. Did you remove the seals from the new bearing?
SS440-80
Real Name: Robert
Post by SS440-80 »
nick80lf wrote:Looks good but I have to ask. I noticed the bearing number on the box was 6202-2RS1. That part number looks to me to be a sealed bearing. Did you remove the seals from the new bearing?
Yes, I just popped out the seals. The RS bearings is the same as the open, but they are greased. It's not much grease and it will flush away with the gas running trough the crankhouse, it will give a little extra smoke in the beginning :mrgreen: I had those bearing lying, so that's why I used them.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
SS440-80
Real Name: Robert
Post by SS440-80 »
Today I made a good work cleaning the gas tank, inside and outside :D
After reading about how the plastic in JD:s gas tanks kind of loosen up in the material, I cleaned the inside with nuts and petrol.
Some strange fluid came out the first time.... :think:
The outside of the tank is very gray of plastic oxide
Gently using a hot air gun to warm out the softner in the plastic brings back the nice black to the outside again :beers;
And after the warm up, a polish with a plastic cleaner makes the tank look new again :dance:
DONE! And a new gas cap is ordered.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
The tank will help make that thing look great!
SS440-80
Real Name: Robert
Post by SS440-80 »
Yes, bringing back the colors in the details makes the whole differens :D
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
skoalmint
Post by skoalmint »
Looks GREAT ! I have NOS oil sending units if you need one . All that heat makes me wander if it will work . Nice job ,keep the pics coming. Brock :beers;
SS440-80
Real Name: Robert
Post by SS440-80 »
Thanks skoalmint :usa:
Good to know if it should fail. But I don't think the heat will take it, the oil tank plastic has a lower melting temperature then the tin soldering.
Here comes some more pics :)
One of the first pictures of the sled in this thread you can se the strap over the seat, it's all green of moss...
I was planning to replace the strap with a seat belt from a car, but somehow I gave the old strap a few minutes of work
And with a good result :lol:
After a spinn in the washing machine it looks like new again.
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
