80 liquifire center crank seal
What's out there for replacement of the center crank seal on the 80s liquifire?
Re: 80 liquifire center crank seal
Might be a question for Jerome at Crankshaft Services. Seems like if anyone would know, it would be him.
Hey Brad,
Since it's a dynamic, non-contact seal, it shouldn't wear. The labyrinth seals like that should be re-useable from another crank if you had one make contact or crack or otherwise fail.
I hope this helps,
I hope this helps,
Yep. Thanks
