M64075 SCREW 4 - 20000 (JDX4)
M64071 LOCK WASHER 4 - 20000 (JDX4)
I need to replace some screws I misplace, you know the ones you put in a safe place, so you can find them later...
These very small allen head screws and lock washers are used to hold the ring gear onto the ring gear hub for the kohler 295 engines. they are Numbers 1 and 2. I am hoping to find a bunch, one kit I have is missing one and the other kit never had any and then there's the ones I lost.
Looking for small screws for ring gear
Re: Looking for small screws for ring gear
any ACE Hardware Store carries a good assortment of Metric Allen head screws, bolts, nuts & washers..
Grumpy
Grumpy
I will have to see if they have some that small. thanks for the tip
