What are the differences between the 78 LF and the 78 LFCC?
jakewalter
Real Name: Jake Walter
Post by jakewalter »
Any information would be appreciated.
Thanks so much,
Jake
fast823
Real Name: Trevor Fast
Re: What are the differences between the 78 LF and the 78 LFCC?
Post by fast823 »
Model Year 1978 Cross Country
TYPE CODE: J34LG
Serial # Range: 80,751 - 80,924
Manufacture Dates: October 1977
Number Produced: 174
Engine: Kiortiz KEC-340/23LC
Horsepower: 45
Notes: Special edition, limited build for cross country racing. Solid rubber track & light weight suspension, exhaust restriction to meet 45 HP limit for racing series, jetting & clutching changes to fine tune. There was also a kit available to convert a standard '78 340 Liquifire to the Cross Country version.
18 and counting
I thought the horsepower limit was 56.
jakewalter
fast823 wrote:Model Year 1978 Cross Country
TYPE CODE: J34LG
Horsepower: 45
Mine is J44LG Date is 9/77 serial # 80480M and mine is a 440 with cleats.
I'm guessing mine isn't a Cross Country.
Thank you for the information,
Sprailfire340
Post by Sprailfire340 »
AirborneX4Special wrote:I thought the horsepower limit was 56.
Pretty sure the 56hp limit was the xc kit for the 80 LF.
:sled: ME
True, but it was a 56 hp kit because that was the hp limit to legally race in the cross country circuit.
Sprailfire340
Sorry for confusion. What I meant was I believe race rules in '78 were 45hp +/- 10% and changed to 56hp in '80.
:sled: ME
Did some poking around, it was 45 hp for 77 / 78, so I stand corrected. Deere had a restricted Y-pipe and different clutch weights installed on the Cross Country to reduce the 47 hp to 45. I would bet the rent it was 56 before 1980, which leaves only 79.
To the original question, all the 78 CC-Liquifire's were 340's, falling within the SN range of 80,751 to 80,924 for 174 produced. The main difference was the long travel rear suspension with a wheel kit, Yokahoma 121 x 15" rubber track with a 3.29" drive lug pitch, triple drive spockets on a hex shaft. The sleds were not sold with the more restrictive Y pipe, racers had to add it as a kit from Deere. It reduced power from 47 down to the race legal 45. Deere also offered the track and suspension as a kit to update regular 76-78 340 Liquifire's for CC racing, along with a roller chain tensioner kit.
As far the HP limits in CC racing, it got a little conflicting in the late 70's due their being more than one cross country circuit until ICCSF folded. The winter of 78 was the first year hp limits were enacted, and it was 45 hp. For 79 I think it moved up to 49hp or so before the 56 hp rules came out in the early 80's. Before that CC racing had either no limits, or just engine size limits. I think 72 or 73 had a 400 cc limit, while 74 had both a 300cc limit and stock engine rules. 75-77 were 340cc limits, stock engine but no hp limits which led to the rise of the factory specials like the 340/s and Liquidator.
I hope this helps,
-Joe Rainville
