I need a push-pull type choke cable which is part # AM54903 for s/n 95001- It is mounted on the left side. This goes to the Mikuni Butterfly (Throttle Plate) style carb. Not sure if the lever style will work since it was mated to the Mikuni slide valve style carb.
Thanks in advance!
~ David
Wanted: 1982 Spitfire Choke Cable
- usafrpilot
- Real Name: David
'74 295/S
'75 JD 800
'75 JDX8
'75 340/S
'76 Liquidator
'78 Cyclone
‘80-84 Liquifires
'75 JD 800
'75 JDX8
'75 340/S
'76 Liquidator
'78 Cyclone
‘80-84 Liquifires
Re: Wanted: 1982 Spitfire Choke Cable
Check out the links on this home page. You can get the cables needed pretty cheap...
Chris
Chris
I just replaced mine with a new choke cable (I replaced the whole carb as well)... I can sell you mine... It is in working condition. PM if interested.
Chris
Chris
