Brake caliper and pads for '76 Liquifire
Mikeebiker
Real Name: Mike
Post by Mikeebiker »
My sled has no caliper on it, just the cable that ends at the bracket. Can the later style of caliper and pad with the square pads be made to work on a 76? Or does anyone have the 76 compatible caliper? Thanks for your advice!
Re: Brake caliper and pads for '76 Liquifire
The 76 caliper is slightly different than the 77/78, but may work. The caliper from a Cyclone is the same as well. You can use the later trailfire caliper if you change the chaincase as well. I may have what you are looking for but I am not at home and will not return until next weekend.
