Snowfire/Sprintfire Suspension Shock
I believe that we have found a suitable suspension shock for Snowfires and Sprintfires. It measures 9.5" closed and 15" open. The top bolt will remain the 7/16 size but the bottom bolt will need changed to a 3/8" or perhaps you can bore the sleeve out to accommodate the 7/16 bolt. The price will start out at $34.95 if no other modifications are required. If anyone has a Snow or Sprintfire suspension out and would agree to test fit this shock I'll make you a special deal. Thanks, Don
