I've got a 1977 300 and the plugs that go in the bottom of the belly pan are missing. The holes measure 2-1/4 inches in diameter. I have tried all over and can't seem to find anything that size. Does someone on here have a source for these?
Thanks.
Belly Pan Plugs
- Real Name: Rod
Re: Belly Pan Plugs
Usually any big hardware will stock 2.25" plugs
- Real Name: Rod
Re: Belly Pan Plugs
I have tried the hardware outlets and everywhere I can think of on the internet but can't seem to find this size.
- Real Name: Kristofer
Re: Belly Pan Plugs
Afternoon I've found over the years that a lot of foreign cars use plastic plugs for the floor holes and trunk drain plugs also on front frame to cover motor mount holes in frame hope this helps. Kris
Re: Belly Pan Plugs
Good advice Kristofer !!
