NOS parts for sale
acesillini06
Real Name: Matt Cappel
NOS parts for sale
Post by acesillini06 »
NOS parts
$10 AM52345 speedometer cable midmount 00's & JDX's
$10 Kiortz mid mount coil
$8 AM53062 lightning winding coil for 400,500, 600,JDX4
$5 AM52379 ignition winding coil model 400
$40 AM54173 trigger Ignition (round plug) 77, 78 Liquifire s and Cyclones
$10 AM54095 needle bearings 1976-78 Liquifire
$15 AM54255 piston ring standard 340 Cyclone & Liq
$10 AM52530 piston ring. 20 oversized JDX4, 300
$18 AM55369 Upper track idle wheel Sprintfire/Snowfire
$40 AM54656 Speedo kit Spitfire
$3 M68586 Intake gasket Spitfire/Snowfire
$3 M68068 gasket cylinder to crankcase Trail, Spit, Snow
$8 M68625 head gasket 340cc Trail, Spit, Snow
$10 M68715 drive belt 80's Liquifires & Sprintfires
$10 7 tooth track sprockets round shaft Spitfire
I have pictures of everything if needed. Let me know what you're looking for.
815-762-6868
Rochelle Illinois
Thanks -Matt
acesillini06
Re: NOS parts for sale
Additional NOS list #2
$10 AM54902 Spitfire throttle cable
$2 M68127 shim ??
$2 M66518 shim for secondary clutch
$2 M68123 seal for Liquifire Kawasaki oil pump
$4 M66797 chaincase plug and red washer
$10 Spitfire NOS speedometer drive 2:1
$10 M67072 Spitfire limiter strap
$3 AM37419 wire lead ground
$10 M67762 Liquifire & Cyclone cooling fan belt
$10 AM54653 Spitfire speedometer cable
$20 80 mph speedometer
$20 8,000 rpm rach
acesillini06
$60 AM53058 Cylinder L.H Model 400
$25 M63622 JDX and 00's cylinder head
$25 M64678 JDX and 00's cylinder head
$25 M66835 Cyclone cylinder head
$25 M68058 Trailfire 440 R.H cylinder head
Thanks -Matt
815 762 6868
