Liquidator 229 Rebuild
hounds84lhs
Re: Liquidator 229 Rebuild
Post by hounds84lhs »
Started working on the sled again. Removed the chain case cover to check over the chain and gears. Everything looked good, except there wasn't any gear oil in the case. Next I pulled the skid and I will start going over that. Just a FYI it is 98% steel and weight 62 lbs.
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
hounds84lhs
Made some more progress this week. Skid was cleaned up, painted, lubed and idler wheel bearing replaced.
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
hounds84lhs
I also cleaned up the pipes and repainted them. I might wrap them, not sure if I will do that. I like how the cleaned up.
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
hounds84lhs
Found a few more problems. Chain case did not have any oil in it when I opened it. Chain has broken links, bottom gear is rough and the top gear is missing a tooth. Glad I hoard parts, found usable gears in one of my three chain cases.
The drives were also bad, cracked and brittle. Using a spare LF shaft and drivers as a replacement. Again, glad I store parts for a rainy day. :beers;
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
Yep. Some folks just ride 'em hard and put 'em away wet.
hounds84lhs
Finally making some progress.
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
Liquifire 4/6
Post by Liquifire 4/6 »
hounds84lhs wrote: Mon Apr 27, 2020 9:58 pm
The drives were also bad, cracked and brittle. Using a spare LF shaft and drivers as a replacement. :beers;
Do the Liquifires and Liquidators have the same pitch drivers and tracks?
Peter from Roblin, Manitoba
Liquifire 4/6
Sure is lookin sweet, Great work!
hounds84lhs
I was told the LF drivers could be substituted. I will let the Dator gurus give the pitch info.
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
hounds84lhs
#229 is ready for the snow. Thanks to everyone who gave advice and help.
83 Trailfire
83 Sprintfire
81 Liquifire
80 Trailfire 340
80 Trailfire 340
78 Spitfire
76 Liquidator
Looks cool
Looks great
Popcorn popper
Real Name: Steve
Post by Popcorn popper »
Looks awesome. Never seen a liquidator in person.
Very nice work! Saved another one! It's always nice when a guy can save a piece of racing history like the Liquidators.
It turned out very nice!
