I just got a 300 motor and it came with a Mikuni carb and wanted to ask if this carb will work.
It has 8H9 01 on the side and measures 38 mm and is a butterfly carb.
Any idea on what jet sizes I should use or what the air idle screw should be set at?
Mikuni on JD 300
Re: Mikuni on JD 300
The Yamaha Enticer 300 used Mikuni 8H9.
The jetting for the ET300 was:
Main jet #210
Pilot jet #90
Air/fuel screw 1-1/4 to 1-1/2 turn out.
That would give you a good start when jetting for your 300.
Main jet #210
Pilot jet #90
Sleds...
2xJOHN DEERE SPRINTFIRE 1983.
YAMAHA GP292b 1973
OCKELBO Trioman 1975
YAMAHA SRV 1982 (shrinked)
YAMAHA SRV 1990
YAMAHA SRV 1991
LYNX Rave 600ACE 2013
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Awesome thank you
Sorry 1 last question any idea of the float height? Thanks
If you look at this link, in chapter 3 you find all info for your carb that you need
http://www.vintagesnow.com/Yamaha_files ... 00g_SM.pdf
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
Again thank you much.
Let us know what jetting you end up with. It could be a good help for someone else sometime...
Sleds...
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
YAMAHA GP292b 1973
YAMAHA SRV 1990
YAMAHA SRV 1991
No problem
