If you have good spark on both sides but under load it seems to fade out to run on one cylinder could this be stator issue or cdi box
79 trailfire stator
79 trailfire stator
Looking for some input here on the stator
If you have good spark on both sides but under load it seems to fade out to run on one cylinder could this be stator issue or cdi box![🤷🏻♂️](//twemoji.maxcdn.com/2/svg/1f937-1f3fb-200d-2642-fe0f.svg)
- SpitfireKing
Re: 79 trailfire stator
I’d try the coil first, I can’t remember if that’s a shared unit on a Trailfire, but if so I’d still aim in that direction to start
