Advice on plug caps and new wires 300 1977
modmod1
Real Name: mario medeiros
Post by modmod1 »
Hi there just wanted to ask which NGK caps should I buy to replace the old ones and what coil wire is to be used? I know on motorcycles with electronic ign you need to use a certain cap and wire but being this is points does it matter? Thanks
modmod1
Re: Advice on plug caps and new wires 300 1977
Post by modmod1 »
I see some say to use non resistor plugs and caps also use 7mm steel core wire? Anyone maybe have a plug number or a cap number for me to use? Thanks
sledz
Post by sledz »
Yes, for a Points motor I would use non-resistor plugs & caps
modmod1
Post by modmod1 »
Thanks will do
