Weak spark on a 1978 spitfire
Has anybody experienced this? The spark is quite weak. Changed plug caps, plugs, ignition ground points and flywheel. Should i pull out stator coil? Im a bit stuck. Any insight would be great
Re: Weak spark on a 1978 spitfire
The most likely culprit is probably the CDI box, followed by the stator, if everything else checks out.
