Can someone make a recommendation on which Mikuni slide carb to purchase to replace the original butterfly carb on the Spitfire kawasaki engine?
Thanks.
Replacement carb for '80 Spitfire
Re: Replacement carb for '80 Spitfire
VM30 is the carb they switched to after the butterfly on the same engine. So you can use the factory jetting specs as well.
