Replacement carb for '80 Spitfire
gordon46
Real Name: Eric Gordon
Post by gordon46 »
Can someone make a recommendation on which Mikuni slide carb to purchase to replace the original butterfly carb on the Spitfire kawasaki engine?
Thanks.
Re: Replacement carb for '80 Spitfire
VM30 is the carb they switched to after the butterfly on the same engine. So you can use the factory jetting specs as well.
