Kevin's Liquifire
Cdnturboz
Real Name: Steve
Re: Kevin's Liquifire
Post by Cdnturboz »
Thanks I'll look into it!
1973 JDX8 (maybe parts sled)
1974 JD400
1975 JD800
1982 Trailfire LX 440
:canada:
Sorry it's been awhile since I posed an update on the 82. Had a few things come up that stalled progress, had to put my dishwasher out of it's misery and I came down with the plague (still trying to shake that).
Even though the 82 wasn't completely finished, I robbed a seat off of one of my 80s and we took it to the show at Honda East in Toledo. We managed to bring home a plaque for best vintage sled. It was a great show and was great to catch up with some guys i hadn't seen i awhile.
When we got home and went to unload sleds we noticed the deck of the trailer seemed to be catching on something when we tried to tilt it (I have a 1999 Triton XT10-101 with a topper). Did a little investigation and found this ugliness.
I've come to realize that this bolt is broken and both halves are corroded fast in extrusion that are welded in the frame tubing. I haven't had a chance to get this apart but I'm sure this is going to be a good time. I did stop at the local Triton dealer to see if this extrusion could be purchased and the answer i got was....no. We will see where this goes.
I did manage to get out to the shop tonight and did install the battery box and ran most of the wiring. Since I'm not finished just yet photos will be forthcoming.
snowmoer
Real Name: Dan
Post by snowmoer »
Congratulations on winning the category! All that hard work paid off.
That stinks on the trailer. I have a 95 Triton. I keep an eye on all the bolts just for this reason. So far, the only thing that I have had to replace was the deck.
Dan
1981 Liquifire
1984 Trailfire LX
2018 Ski Doo Summit Sport
The bad thing about the way these Tritons are made is that if the bolt corroded into the aluminum spacers the bolt can appear to be intact when it's not. I bought mine used in about 2013 and my suspicion is that the bolts were corroded fast long before I bought it. Talking with my son he believes my wife broke it when she recently borrowed it to haul some stuff for a function at school. He recalls her saying she heard a loud pop when they were loading (more like overloading) it.
Sorry it's been awhile since I've put up some photos. I've been dealing with back issues the last few weeks and have been staying out of the shop. I ventured out there today to attempt to winterize the wife's camper. While I was there I snapped some photos.
First one, here's the completed e-start system (sort of).
The battery in the photo is totally pooched and is only there for the photo op. This battery came out of a mobility scooter that seems to have taken permanent residency in my shop. Since my mower also uses a U1 battery my original plan was to use that battery in the sled (I don't use the mower to move snow, so why not?). When I dropped this sealed group U1 battery in I started to think it would be a good idea to use an AGM U1 instead of the plain flooded U1 currently in my mower. Did some investigating and it turns out you can get a AGM U1 battery. Ultimately this is the direction I want to go, just haven't purchased said battery yet.
Next is the seat. Here are photos of the seat I'm going to run on this sled.
This was the first time I've used the 3M headliner adhesive that John recommended. The good is....this stuff really sticks. The bad is.....this stuff really sticks. I'm not totally happy with the tail light area but I've never been happy with these and this is the best I've had one ever turn out. I would recommend letting your seat set for a few days before installing it if you use this stuff. I probably only let it set for about 2 hours before installing on the sled. When I pushed the rear corners down to install the bolts it caused the vinyl to stick to it's self. I don't think the contact cement was totally set up. I was able to work it out some but there's still a little wrinkle there.
Oh....forgot to mention this. When i bought this sled the key had been lost. I had intended to replace the switch but wanted to keep things as original as possible and didn't want to use the aftermarket switch that is available. So in the end, here is what I did. Turns out you can still purchase a genuine Indak switch from Arctic Cat that has the same pin out and uses the same "A" key cut. The only difference is the original deere switch had what I believe Indak called a start lock out. Basically you only had one shot at the start position after that you had to go to off before going to start. I assume they did this so someone wouldn't engage a starter with the motor spinning 8k. The Arctic Cat switch does not have this feature. Don't remember the Cat part number but these were used on the Kawasaki powered sleds from the 70s.
The second thing is Deere still offers the "A" cut key for this switch. It will have the new logo on it. These were used on the early Gators.
For those wondering the Deere part number for the key in the photo above is AM131841.
High Top
Real Name: Keith B
Post by High Top »
nick80lf wrote: Sat Nov 02, 2024 12:54 pm Sorry it's been awhile since I've put up some photos. I've been dealing with back issues the last few weeks and have been staying out of the shop. I ventured out there today to attempt to winterize the wife's camper. While I was there I snapped some photos.
I just got a battery a while back to put in my sportfire. I searched a while on the interstate site and went with a power sports one. It was smaller than the box dimensionally but I just put some foam spacers in on the sides. It cranks it over really well and sure beats pulling the rope! Here is the model and how it looks in the box.
Did you staple your seat cover to the wood or just use the glue? I’ve used that 3M stuff at work on cab upholstery and it is definitely good stuff. Also the 3M general purpose adhesive remover is the best stuff I’ve ever used to get sticky anything off.
Keith
79 Trailfire 440 (2023)
80 Trailfire 440 (2023)
80 Trailfire 440 (2024)
81 Sportfire (2024)
I did staple the seat cover over the wood, used monel and stainless staples (I ran out of monel and wasn't paying that much for more so I switched to stainless). I used the headliner adhesive only where needed (butt area and tail light area). In the past I've tried super 77 and didn't have much luck with it holding long term.
Just an FYI. I believe the Arctic Cat part number for the Indak e-start switch that is used was 0609-278.
