81 Trailfire
81 Trailfire
I have a 1981 Trailfire with the fan cooled Kawasaki 440 engine. I removed it, took it apart and installed new seals. It went back together very smoothly. I reinstalled into the sled today and now it doesn't have spark. Any thoughts? Stumped!
Re: 81 Trailfire
Try unplugging the wire harness (5 pin connector) from motor and check for spark.
- Real Name: Tom Schuster
Re: 81 Trailfire
If the key switch and the emergency switch are both good, you may have a pinched wire on the stater reassembly.
Re: 81 Trailfire
Yep....when you turn the key it grounds the ignition. Unplugging the harness from the motor will remove that connection. If the motor starts with the harness disconnected the kill switch or key switch will not work.
Re: 81 Trailfire
I found the problem. When I was pulling the flywheel I must have put one of the puller bolts too deep at it damaged the coil.
Re: 81 Trailfire
Ouch....bolt depth always makes me nervous pulling flywheels. A few years ago i finally gave in and purchased a SLP flywheel puller. It's been awhile since i have used it but I think the bolts they included are just the right length to prevent that from happening.
Re: 81 Trailfire
I'll not make that mistake again.............I hope
