1981 Liquifire restoration
JDcarlor
Real Name: Carter
Re: 1981 Liquifire restoration
Post by JDcarlor »
I got a little more work done on the liquifire today. The crankcase is back together and the new pistons are on.
My sandblasting did not go as planned because our air compressor is to small and couldn’t keep up. I am going to have to go to my grandpas sometime and use his air compressor to sandblast.
snowmoer
Real Name: Dan
Post by snowmoer »
Your making good progress!
Dan
1981 Liquifire
1984 Trailfire LX
2018 Ski Doo Summit Sport
JDcarlor
Real Name: Carter
Post by JDcarlor »
The engine is looking like an engine again! I installed the cylinders, heads, water manifold, and oil pump tonight.
Wow....good job. Just a question, I see orange sealant. Back in the late 90s I bought a tube of sealant from my Deere dealer. They followed the trail of substitution and it ended up being some orange stuff made by GE. Would this happen to be what you used?
JDcarlor
Real Name: Carter
Post by JDcarlor »
It is red RTV. My dad is a John Deere salesman and he did some cross checking with the original part number and this is what it cross referenced to.
Cdnturboz
Real Name: Steve
Post by Cdnturboz »
Looks good
1974 JD400
1975 JD800
1982 Trailfire LX 440
JDcarlor
Real Name: Carter
Post by JDcarlor »
It seems I am missing some bolts. The other engine is also missing them so I can’t rob them from that engine. Does anybody know what size bolts go here in the bigger holes of the gear case cover and if they need washers and lock nuts? If so please let me know. Thanks
snowmoer
Real Name: Dan
Post by snowmoer »
I looked at the parts book and it shows a bolt, lock washer and a flat washer. The book did not give a bolt size. They should be metric. Also make sure you have the spacer washer that goes over the hole in the case at the 2 o'clock position.
If you don't have the shop and parts manual, here is where you can download them.
https://www.vintagesnow.com/
Dan
1981 Liquifire
1984 Trailfire LX
The four bolts around the crank bearing attach the crank side of the motor to the bulkhead. They are socket held cap screws. I'll have to dig and see if I can find some to measure the lenght. When i seal up the oil pump case i usually install those bolts to hold the cover tight until the sealant cures.
Seems like these socket head cap screws are M8x25. The Deere to kawasaki cross reference shows Deere M68115 is Kawasaki 120PO-825.
JDcarlor
Real Name: Carter
Post by JDcarlor »
snowmoer wrote: Thu Apr 03, 2025 12:09 pm I looked at the parts book and it shows a bolt, lock washer and a flat washer. The book did not give a bolt size. They should be metric. Also make sure you have the spacer washer that goes over the hole in the case at the 2 o'clock position.
I am not sure what you are talking about with the spacer. If you could send a picture that would be appreciated. Thanks!
JDcarlor
Real Name: Carter
Post by JDcarlor »
Thanks for the help on the bolts everyone. I believe I have them in the bin of bolts I received when I got the mostly disassembled sled. I was not sure which ones exactly they were however. I had kind of forgotten about the parts breakdown manual. My dad had pulled up some diagrams for me online before but I hadn’t thought to do that again. I might just end up printing the whole thing for future use.
snowmoer
Real Name: Dan
Post by snowmoer »
JDcarlor wrote: Fri Apr 04, 2025 7:55 am
I don't have a picture of it. It is a spacer/washer that the gear for the oil pump rides on with the dowl pin. Download the parts fiche in the link I posted and you will see what I am talking about. Part #15. There is one on both sides of the gear.
Dan
1981 Liquifire
1984 Trailfire LX
High Top
Real Name: Keith B
Post by High Top »
Here are what mine look like.
Keith
79 Trailfire 440 (2023)
80 Trailfire 440 (2023)
80 Trailfire 440 (2024)
81 Sportfire (2024)
80 Liquifire (2024)
JDcarlor
Real Name: Carter
Post by JDcarlor »
Progress has been slow as I have been busy with school lately. Hopefully it will pick up again but we will see.
