340S
8ho
340S
Post by 8ho »
2012#
JRC ETD
340S
Post by JRC ETD »
If need be I can make them at the shop, but will need a original, rings are another story!
340S
Jon,
Several of us have horded rings from the 340/s & Dator pistons. KD was blowing them out cheap a few years ago. I think we could ring several sets of pistons w/o an issue.
8ho
340S
Post by 8ho »
I got a set of ring awhile back they said they would fit 340/s and dater not even close. I will get the part# later
Dator76
340S
Post by Dator76 »
79 340 trailfire rings are very close, also wiseco will sell rings but they need you to measure sizes. one of those people that have the std. replacement dator pistons manufactured a couple years ago might look at the part number on the rings (if there was one)
Ted
3 Liquidators
1-340/S
1-295/S
1-78 Cross Country Liquifire
I500
Real Name: Chuck Moser
340S
Post by I500 »
If anybody is looking at repoping 340/s pistons and need a donor let me know as i have a few around here. Last i heard Kenny has about a zillion rings.
8ho
340S
Post by 8ho »
can anyone tell me wnat piston these fit AM53544. got these off the net a year or so a go and was told they fit 340/S but they do not
340S
Well the John Deere parts catalog says it fits the 340/S. May have been mispackaged, or.......misrepresented.
8ho
340S
Post by 8ho »
Got them from a guy in canada off e-bay. the 3 motors I got have art's piston in them with two thin rings. the rings he sold me one is too thick and the other is too thin P.S. any one in mid-michigan looking for trailfires went to a yard sale on waker road just north of 21 guy had four of them
Rodimus Prime
340S
Post by Rodimus Prime »
i have a local guy who custom makes rings depending on what you got.
the 340/rs and the 340/2/3/5 engines share a same diameter piston, pin size i think is different. the rs pistons however have finger ports where the 340/2/3/5 do not.
However if your completely stuck for a piston for this engine and can work around pin size the rotax fan cooled 340 piston 0.020 over works. also 340 air cooled rotax 0.020
Note some 340 rotax pistons have straight skirts some have angled.
if you really want to be picky althought its not needed unless racing the finger port can be drilled into other pistons. all it does is put a precharge into cylinder from under piston. some think the precharge is advanced porting or longer port opening.. nope its the hole in piston.
thin rings sound like a wiesco piston. if memory serves superstock 340/rs pistons are single l ring titianum pistons. normal pistons are 2 ring both have holes wiesco some did some didnt.
