Mikuni Jet
Mr. Deere
Mikuni Jet
Post by Mr. Deere »
Cant help ya with the test but what you could do to start is get all the correct jetting in the sled. You are going to have to do it anyways might as well do it now to see if thats the problem. If you want i can post up the jets from the fine tune manual for you. BOB
jdcat
Mikuni Jet
Post by jdcat »
Air screw on this mikuni is behind the air box boot.Throttle stop screw near the carb boot. Both on left side of carb.
Mr. Deere
Mikuni Jet
Post by Mr. Deere »
Weird mine are different. BOB
jdcat
Mikuni Jet
Post by jdcat »
Only markings on the carb are MIC 500 61. Not even sure its a VM carb.It does have overflow outlets on top & bottom of carb bowl.
jdcat
Mikuni Jet
Post by jdcat »
Course this is a single 34mm carb.
Mr. Deere
Mikuni Jet
Post by Mr. Deere »
Might not be then. I will get you the jetting and the correct carbs that were supposed to be on it. Let me go get my book. BOB
Mr. Deere
Mikuni Jet
Post by Mr. Deere »
What temps will you be running this sled in above or below zero (Majority) also what Altitude above sea level. BOB
jdcat
Mikuni Jet
Post by jdcat »
Possible somebody stuck a power jet carb on this engine? Dont know if any of the vm carbs had an overflow fitting on the bottom of the carb.I know they had it on top.
Mr. Deere
Mikuni Jet
Post by Mr. Deere »
Well according to my book Your 79 Trailfire would take 1 VM34 NON POWER JET. BOB
jdcat
Mikuni Jet
Post by jdcat »
Already know the main jet is 230 ,pilot 25. This is right. Cut away in the slide may affect idle some, But a 3.0 is richer than a 3.5, Youd think id have to lean out the air screw to use the 3.0. Instead i have to richen it for any idle. Needle jet and all else have to do with 1/4-1/8 throttle & up.Unless im wrong on carb function it should idle with the 230 main & 25 pilot. I Think Danzig is right & im missing a air leak somewhere. Just though i could get the engine to idle,Run it Make sure lower end & crank are ok before putting another 50-60 bucks into the carb.
Mr. Deere
Mikuni Jet
Post by Mr. Deere »
OK anyways I left you a Pm with the Jetting Specs. BOB
Danzig
Real Name: Paul File
Mikuni Jet
Post by Danzig »
Go to the FAQ forum and look up pressure testing an engine.
jdcat
Mikuni Jet
Post by jdcat »
Looks like im stuck with the 6F9 jet needle on my trailfire.The 6F27-3 that i need is non-existant, At least a week of searching online hasent panned out.
Mr. Deere
Mikuni Jet
Post by Mr. Deere »
The jet itself is only 6F27 the three is for the clip on the Needle. All you need to look up is 6F27. BOB
That Girl Racing
Real Name: Peter
Mikuni Jet
Post by That Girl Racing »
The biggest mains available from Mikuni are 720s. The aftermarket makes bigger ones. We use around 1080s on our race sleds with EE0 tubes. Peter
