Mikuni Jet
Mikuni Jet
Beware of trying to rejet your mikuni to pip specs.The [166 series] Q-O needle jet JD recomended is made for Vm 38mm carbs.I ordered a 166 ,tried to install it & being a shorter needle jet you have no threads to install your main jet to. I had to eat the 19.00$ jet {special order}, & order a 159 series in a Q-O. The 159 is listed as for 30-36 mm vm carbs.
