After looking at the Intruder closer I noticed some repair work on the power jet elbow where the power jet line goes into the inlet of the carb. Looks like they JB welded that white plastic elbow together.
So I thought I would check to see if anyone has an extra carb for a 440 Intruder motor or extra parts that I could use.
Eric
Wanted
Wanted
Is the Nipple broken off or the whole piece. If so this happened to me and I got one of those screw in brass fittings the go in the primer holes. Threaded it right in and it works fine. BOB
Wanted
I'll have to investigate. Planning on pulling the carbs tonight and see what exactly is going on.
Can those white elbow fitting be purchased?
-Eric
-Eric
Wanted
No I had the same problem and they told me new carbs or trying one of those kits DK sells that are to convert Non PJ carbs to PJ carbs. BOB
