Power Jet Outlet Plastic Fitting
I am getting ready to soak the carbs in carb cleaner and the cleaner says not use on plastic components. I looked through the tech manual and it does say to remove gaskets but that it is it. Will I damage the power jet outlet plastic fitting if I place the whole carburetor in the carb cleaner. Thanks again for the help
Nope I dip mine all the time. What kind of cleaner are you using?
MIke
MIke
I am using Gunk (1 gallon w/ a basket). Another question. In the attached photo which jet is the main and the power jet. Is it the lower jet (barely visible in the photo) and the main a hex head in upper portion of photo? The lower jet is a 145 and the upper a 110. This is the carb from the PTO side. According to the Tech manual the power jet is a 110 and the main a 150. I am a little confused because the jets seem to be the reverse of what they are suppose to be.
the main jet is a hex head & the power jet is screw driver type.
follow the rubber hose from the main carb body to the float bowl & see which hole it leads to as that is the power jet..
It sounds to me that someone was trying to lean out 1/2 throttle by going as lean as a 110 main & then trying to fatten up the WOT by using a 145 power jet & the 110 main???
Not the way I would have done it but everyone has different ways of doing things..
- Danzig
- Real Name: Paul File
Please Note!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
THE PICS DESCRIBING THE MAIN AND PILOT JETS IN THE MANUAL ARE WRONG. LOCATION IS CORRECT IN THE PIC PER THE MANUAL BUT NOT THE NAME!!!!!!!!!!!
