kiotitz kec 340 23 lc
wgrdafoe
Post by wgrdafoe »
hello iwas wondering where to find crankshaft seals for a kec 340 23LC,the dimensions are30,62,8 and 25,62,8.The only seals i can find for John Deere are listed for different dimensions.Thanks
You probably could use a 30-62-10 & a 25-62-10 as the 2 mm extra in width is only .0787" I believe that the the above mentioned would be a more popular seals.
You should be able to get any size you need form MN Vintage snowmobile (link above) or Kimpex or Dennis Kirk or any other snowmobile dealer.
Central Snowmobile lists seals by their numbers.
They show them as 7mm wide though.
wgrdafoe
Post by wgrdafoe »
Is it possible John Deere would still have these seals.
Mag side M66694, PTO side M66555, hard to say, you could ck, but I'm not so sure I would want a NOS seal that has been laying around in some parts bin for 30 years
Kimpex has 30-62-10 Kimpex number 09-127 & 25-62-10 Kimpex# 09-116
30-62-8 Kimpex # 09-140
Kimpex shows the M66555 to be a 30-52-10 Kimpex number 09-144 You might want to double ck your numbers on your seal??? or it could be a miss print in there book also???
Kimpex USA
Champlain NY
1-800-777-7073
wgrdafoe
Post by wgrdafoe »
No luck with jd seals,so i ordered the 10mm wide,thanks for the help.
Let me know if they work OK, I'd hate to be giving out misinformation.
