My 80 LF oil injection pump gave trouble a couple years ago. The trouble was it would take a way to much oil through. I just quite using it and have since been mixing oil with the gas. I was just wondering if anyone else had had this same problem.
MARK
Liquifire
Liquifire
Not a good idea to use only pre-mix oil on 80's Liquifires. Besides each cylinder getting an oil line, the LF's also had the center bearing on the crank getting an oil line. If you pre-mix the oil and don't run the oil injection system, that center bearing isn't getting nearly enough oil. This will ruin the bearing, crank, and maybe a lot more. The injection is a good system and is properly adjusted, won't use that much oil. Was yours peoperly sync'd with the carbs?
Bob
Bob
grasscutter97
Liquifire
The check valves are available from numerous parts stores and I hve found they are the cheapest at any Polaris dealer. Real good idea to replce them, its only a few bucks.
After going through my injection system on my 81 Liq, I replaced both valves, lines, etc. Noticed I used a little bit less oil per fuel tank than before, and plugs were significantly cleaner. So, I concluded that my system, even though operational, was in need of a tune-up.
